18 years agoWhat can I do if I come across following question?
Error: Can't generate netlist output files because the file "E:/2008-04-01/DDR_71/auk_ddr_hp_controller.vhd" is an OpenCore Plus time-limited file
18 years agoPlease check you have valid license for DDR SDRAM High Performance Controller and this by default comes with encrypted time limited opencore pluse license so only time limited sof will be generated!
