13 years ago
web server on FPGA
i want to implement web server application on the FPGA but i don't really know how to proceed.i'd like to ask which protocol i should use(http, ftp, tftp..) and even how to use it if i will read real time data (images from the SDRAM).
is there someone who tried it and can help me?
thanks in advance..
mira.
    --- Quote Start ---
    Hi mira- there is a web server IP core available for free download at www.webphyfpga.com (http://www.webphyfpga.com). It implements HTTP/TCP/IP/MAC and even PHY layers completely within the core - no CPU, DDR, flash memory, OS or external PHY chips are required. Just download the core, drop it into your FPGA and wire the FPGA's LVDS IO directly to a mag-jack and your FPGA is web-enabled. The web page can be completely customized as well and is stored in block RAM in the FPGA.
    --- Quote End ---
    Hi I am just starting with FPGA programming. I have no idea about which tool to use for converting html files so that it can be stored inside data flash memory. Can you please help me.
    Hi mira- there is a web server IP core available for free download at www.webphyfpga.com. It implements HTTP/TCP/IP/MAC and even PHY layers completely within the core - no CPU, DDR, flash memory, OS or external PHY chips are required. Just download the core, drop it into your FPGA and wire the FPGA's LVDS IO directly to a mag-jack and your FPGA is web-enabled. The web page can be completely customized as well and is stored in block RAM in the FPGA.
    ok i find all web server features provided by altera (ftp,http,telnet,...) .if i want to run ftp what shall i do?
    Hi Cris,
    thank you for replying.
    well, i'm using stratix II RoHs but i didn't find the reference design in the dev kits page!! can you give me a link ?
    thanx
    Most dev boards with connectivity features have at least a reference design and sample code for WebServer functionality. As a starting point, go to dev kits page on Altera website and browse the related documentation.
