14 years agoWeak pull-up setting is ignored
Hi, please help me with this issue. I am stuck with enabling weak pull-up on the I/O pins. I set whole bus's defined by the location earlier weak pull-ups to ON, but fitter ignores it. How to do it p...
14 years agoI'm not sure what you mean by "the fitter ignores it" but the pullup may be weaker than you think. Try using the Assignment Editor to assign "Passive Resistor" which can be pulled either up or down.
