15 years agoVirtex-6 XC6VLX195T device
Looking for a comparable Altera device? any ideas? thanks
15 years agoHi Dave,
I have 2 vhdl files each containing the definition for one of the lookup tables used in the CRC calculation. On one hand I have 256x32-bit single-port distributed Read Only RAM (LUT) and on hte other hand 256x32-bit single-port distributed Read Only RAM - BRAM based. I need to configure BRAM vhdl file in order to use memory blocks you mentioned. I tried using MegaWizard but I couldnt locate altsyncram megafunction. Could you be able to give me an example on how to do this? Thanks, mj
