15 years agovht test bench examples
Hello, I am specifying altera to generate a .vht test bench for my vhdl project. I want to modify this test bench so that I can specify the input signals to be some value at different times ins...
15 years agoSorry, the wait signal in my code is commented out. I copied your code exactly as you specified in the section the vht generated test bench says to put code you want to run indefinetly. However it is still not showing up on my signal viewer.
