15 years agoVHDL timer
hi, how can I write a program for a timer which Measures a pulse width that represents of range.i'm using un ultrasonic sensor, The distance can be calculated using the scale factor of 147u...
13 years agohie i am a newbie ..
i managed to create a program that read input from the PIR sensor from the gpio and when sensor sense movement it will turn on and LED on the DE2 board. how can i write the timer that stays on for 5 to 10 minutes. here i attcehed my code... library IEEE; use ieee.std_logic_1164.all; use IEEE.numeric_std.all; entity ltestinggpiowithdelay is port( GPIO_0 : in std_logic_vector(2 downto 0); q : out std_logic_vector(2 downto 0)); end ltestinggpiowithdelay ; architecture bufferwithGpio_arc of ltestinggpiowithdelay is begin process(GPIO_0) begin if (GPIO_0(0)='1') then q<=GPIO_0(2 downto 0); else q<= "000"; end if; end process; end bufferwithGpio_arc;
