15 years agoVHDL timer
hi, how can I write a program for a timer which Measures a pulse width that represents of range.i'm using un ultrasonic sensor, The distance can be calculated using the scale factor of 147u...
15 years agoI just saw you want VHDL.
The Altera code for VHDL is:
library ieee;
use ieee.std_logic_1164.all;
use ieee.numeric_std.all;
entity count is
port
clk : in std_logic;
reset : in std_logic;
enable : in std_logic;
q : out integer range 0 to 255
end entity;
architecture rtl of count is
begin
process (clk)
variable cnt : integer range 0 to 255;
begin
if (rising_edge(clk)) then
if reset = '1' then
-- Reset the counter to 0
cnt := 0;
elsif enable = '1' then
-- Increment the counter if counting is enabled
cnt := cnt + 1;
end if;
end if;
-- Output the current count
q <= cnt;
end process;
end rtl;
