15 years agoVHDL timer
hi, how can I write a program for a timer which Measures a pulse width that represents of range.i'm using un ultrasonic sensor, The distance can be calculated using the scale factor of 147u...
15 years agoFrom what I read the circuit will measure the number of clock pulses.
Each clock pulse has a fixed duration (T = 1/fclk). First try to understand what your circuit is. This means input and output signals and internal circuitry. You need: 1) A signal that enables counting (input) 2) A clock (input) 3) A reset (input) 4) The duration of the measured pulse (output: how many bit?) The circuit could be a simple counter wich counts the high duration of a signal. The Altera example for a counter (Verilog) is:module counter
clk,
reset,
result,
ena
input clk;
input reset;
input ena;
output result;
reg result;
always @(posedge clk or posedge reset)
begin
if (reset)
result = 0;
else if (ena)
result = result + 1;
end
endmodule
I think this is a good start.
