15 years agoVHDL robot design not working
Hello everybody I'm new in VHDL and I'm doing a project with DE2 board In the project I need to build a robot. My first step was to design a ASM and from that to take out the FSM which i...
15 years agoTo make LED connect to RD_LED, just assign it outside of a process. Or if you want to make it a variable, just assign LED above if counter = 50000 then.., and asign RD_led (as a variable) where it is now. Variables can store values between clocks if you put things in the right order.
For DC, because it is set a value and nothing else, Quartus will probably just assume it is a constant. But making it a generic might be a good idea. Generics are created like ports, in the generic section:
entity my_ent is
generic (
DC : integer;
port (
end entity my_ent;
Then when you do the instantiation, you give it a value.
my_inst : entity work.my_ent
generic map (
DC => 32678,
port map (
Inside your entity, you just treat generics like constants.
