15 years agoVHDL robot design not working
Hello everybody I'm new in VHDL and I'm doing a project with DE2 board In the project I need to build a robot. My first step was to design a ASM and from that to take out the FSM which i...
15 years agoyour right I do need to simulate the code first...
I wrote a tb for the code but i dont see any waveform way?
library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_arith.all;
use ieee.std_logic_unsigned.all;
--use std.textio.all;
--use ieee.std_logic_textio.all;
entity tb_pwm is
end entity tb_pwm;
architecture arc_tb_pwm of tb_pwm is
signal Clk : std_logic := '0'; --
signal Rst : std_logic := '0'; --
signal Sw : std_logic_vector (2 downto 0):= "000"; --
signal Enable : std_logic := '0'; --
signal Pwm : std_logic; --
signal Led : std_logic_vector(7 downto 0); --
begin
test : entity work.pwm
port map (
Clk => Clk,
Rst => Rst,
Enable => Enable,
Sw => Sw,
Pwm => Pwm,
Led => Led );
Clk <= not Clk after 10 ns;
Rst <= '1' after 20 ns;
process
begin
wait until Rst = '1';
wait until rising_edge(Clk);
Enable <= '1';
wait until rising_edge(clk);
Sw(0) <= '1';
Sw(1) <= '0';
Sw(2) <= '0';
wait for 100ms;
Sw(0) <= '0';
Sw(1) <= '1';
Sw(2) <= '0';
wait for 100ms;
Sw(0) <= '0';
Sw(1) <= '0';
Sw(2) <= '1';
wait for 100ms;
Enable <= '0';
wait for 100ms;
Rst <='0';
wait for 100ms;
end process;
end architecture arc_tb_pwm;
