15 years agoVHDL robot design not working
Hello everybody I'm new in VHDL and I'm doing a project with DE2 board In the project I need to build a robot. My first step was to design a ASM and from that to take out the FSM which i...
15 years agoThe code:
library IEEE; use IEEE.std_logic_1164.all; use ieee.std_logic_arith.all; use ieee.std_logic_unsigned.all; Entity Pwm is Port ( Rst : In std_logic; Clk : In std_logic; s : In std_logic; Enable : in std_logic; Led : buffer std_logic_vector (7 downto 0); Pwm : Out std_logic ); attribute altera_chip_pin_lc : string; attribute altera_chip_pin_lc of clk : signal is "@N2"; attribute altera_chip_pin_lc of rst : signal is "@G26"; attribute altera_chip_pin_lc of Led : signal is "@AE23, @AF23, @AB21, @AC22, @AD22, @AD23, @AD21"; attribute altera_chip_pin_lc of s : signal is "@N25"; attribute altera_chip_pin_lc of Enable : signal is "@N26"; end entity Pwm; Architecture arc_Pwm of Pwm is signal Counter : std_logic_vector (16 downto 0); signal DC : std_logic_vector (16 downto 0); begin PwmReg: process (Clk,Rst,s) begin if (Rst='1') then Counter <= (others=>'0'); Pwm <= '0'; Led <= (others=>'0'); DC <= conv_std_logic_vector(32678,17); --duty cycle 50% elsif rising_edge(Clk) then if (Enable='1') then if (Counter = 50000) then Counter <= (others => '0'); elsif (Counter < DC) then Counter <= Counter + 1; Pwm <= '1'; if (s = '1') then led <= Led + 1; if(Led = "11111111") then Led <= (others=>'0'); end if; else led <= Led - 1; if(Led = "00000000") then Led <= (others=>'1'); end if; end if; else Counter <= Counter + 1; Pwm <= '0'; end if; else Pwm <= '0'; end if; end if; end process PwmReg; end architecture arc_Pwm;
