15 years agoVHDL Noob question- Recursion?
Hello, I am studying VHDL and am at the topic of signal changes in dataflow and behavior style architectures. So I have two questions. 1) Will the "compiler" ever allow a scenrio where r...
15 years agoThe construct involves a logic loop rather than recursion. In the present example, the logic loop can either act as a latch or a ring oscillator, depending on the state of signal A.
Apart from the question if the design serves a reasonable purpose, it's basically synthesizable. The compiler will issue a warning about generating a logic loop. The A='1' F='0' ring oscillator case will cause problems in simulation (signal changing every simulation time step) and probably excessive current consumption in hardware.
