15 years agoVHDL newbie : package and "use" directive
Hi ! However hard I try to insert those 2 lines in my vhdl top level design (multiplexer.vhd) : library WORK; use WORK.multiplexer_Pkg.all; my component instantiations located in my to...
15 years agoHi Tricky !
Thanks for your answer. If you replace the line 68 of multiplexer.vhd :genericMultiplexer_i : work.genericMultiplexer( genericMultiplexerArchi )
by genericMultiplexer_i : genericMultiplexer( genericMultiplexerArchi )
it won't compile whereas it should, at least if I've got a grip with "use package" statement ... :-( Cheers ! Sylvain
