15 years agoVHDL integers initialization and FPGAs
I've started coding in VHDL just less than a year ago - unexperienced student warning! My question is about integer initalization. I own an Altera DE1 board and I've also got some experience wi...
15 years agoI simulated using ActiveHDL, so there's no testbench code since I didn't need it. I could write one if you'd like.
Maybe you'd rather like to see simulation results? Edit: ha, this is interesting. I just tested it again using 'to' instead of 'downto' in the declaration (without the := 0 initialization), and it also worked fine. So I guess it's a compiler related issue?
