15 years agoVHDL HC237 3-8 Decoder with latches
Hello, I'm trying to write the VHDL code for chip HC237. I think I have something written that will work for the most part, but my problem is in dealing with pin GL. Basically what this chip does i...
15 years agoI would not try and build transparant latches - you will run into all sorts of problems as you cannot garante timing with them. You would also be creating latches for Y because it is not given a value when GL = '0'. And if A,B,C are meant to be the bits from I, you cannot drive an input port.
I would first bring a clock into the design, it will make your life much much easier.
