18 years agoVHDL-Generics
Hi, I have instantiated a VHDL component in my top level VHD. I want to use generics to pass some constant values. Are generics synthesisable and implementable in actual hardware when i do...
18 years agoThe simple answer is yes!
The generic does not actually synthesis to any logic itself but will control what and how your logic is built. For example if you have a generic that specifies a bus width, it will set the bus width to the generic value during synthesis. Hope this helps
