14 years agoVhdl codes for counter to start and purse
I need urgent help on how to design a stopwatch that can stop/purse using vhdl code. I will really appreciate any urgent reply to this. Thanks. Waiting for your replies.14 Replies
how can i design the clock such that if i press pause at intial state, there should be something to remember that state so that Wwhen i do that, the button will change to the next state i.e 1 to 0.
is majoprly on the start./stop and nothint else. thats all i need for now.
Thanks. - Altera_Forum
anybody with idea on how to implement this. I need it urgent.
or If you know how to apply flip flop, logic gate to manipulate the start and stop button, I will appreciate it. Thanks one switch represent start and stop. All I want is that instead of holding the switch down to stop counting, I want it to stop counting if I also remove my hand. and again If I do same thing, i want it to start counting.... Please If you know what I mean, kindly help me out. Thanks - Altera_Forum
The best way to achieve what you are asking is to draw yourself a flow chart. If you are looking for an on/off button with just one push then you would have something like this.
Now, you can register the pulse, add debounce, ect. It is up to you. Next, you need to create a state machine to handle the enable to your counter. From what you've described you have 2 states, on and off. you start in the off state, if the button_pulse = 1 then you go to the on state and again if the button pulse is 1 you go back to the off state. Then you describe your counter enable as 1 when in the on state and 0 when in the off. I recommend drawing this out and then creating your state machine to match your diagram.process(clk) begin if(rising_edge(clk)) then button_prev <= button_curr; button_curr <= button; end if; end process Button_pulse <= button_curr AND (NOT button_prev);
