15 years agoVGA display mode
hi: in the DE2 demo,there is a "VGA_Param.h" file ,in this file,pixel display frequency is 25MHz,I want to replace it of 50MHz,so I think the Horizontal Parameter and Virtical Parameter should...
15 years ago- check that your screen supports your video parameter : frame rate and resolution
- check the width of every counter in your code. you need higher maximal values, maybe some counters can't reach these values.
