15 years agoVGA display mode
hi: in the DE2 demo,there is a "VGA_Param.h" file ,in this file,pixel display frequency is 25MHz,I want to replace it of 50MHz,so I think the Horizontal Parameter and Virtical Parameter should...
15 years agokevin,thanks for your reply~
in 25MHz mode,the parameters are as follows: format horizontal parameters vertical parameters 640*480,60Hz, 640 16 96 48 480 11 2 31 then in 50MHz mode,the parameters are replaced by : format horizontal parameters vertical parameters 1280*480,60Hz, 1280 32 192 96 480 11 2 31 but I also get the message from VGA says"the ouput data is too much to display",then I change those parameters according to the webhttp://martin.hinner.info/vga/timing.html (http://martin.hinner.info/vga/timing.html) format horizontal parameters vertical parameters 800*600,72Hz, 800 56 120 64 600 37 6 23 in 25MHz mode,I can get nice image,but when I try to change the pixel frequency to 50MHz, I cannot get any image,there is always "ouput data is too much to display" in the VGA display screen~ I have think about the VGA display mode for serveral days,but I also cannot get any meaningful conclusion~
