18 years agoVerilog to VHDL
Can some one tell my what this code is in VHDL?
always @(posedge vga_clk or negedge reset_n)
begin
if (reset_n == 0)
sync_n <= 0;
else if (1)
sync_n <= vga...
18 years agoI believe the following example would be equivalent VHDL for your Verilog. The
VHDL you provided appears to be machine generated. process (reset_n, vga_clk) begin if (reset_n = '0') then sync_n <= '0'; elsif (vga_clk'EVENT and vga_clk = '1') then if (vga_start = '1') then sync_n <= vsync_temp xnor hsync_temp; else sync_n <= sync_n_init; end if; end if; end process;
