15 years agoVDHL / verilog ?
bonjour I use fo many years AHDL but with quartus 10 I must change. What is the difference between VHDL and Verilog? which is better? thanks
15 years ago --- Quote Start --- Its like asking if you should buy apples or oranges. They are two different things at the end of the day and those that like oranges will try and convince you to eat them, while the apple camp will try and make you buy apples. At the end of the day they are both fruit with a juicy centre and plenty of nutrition. Seriously - if you like C, you're probably better off with verilog, and I think AHDL has more of a Verilogness to it. But personally Im a VHDL man (with almost no verilog experience, but some time ploughing through old AHDL designs and interfacing them to newer VHDL). Toss your coin. --- Quote End --- Hi Tricky, Seriously, I like your analogy but prefer to think of Shish kebab (VHDL) Vs Tika kebab (verilog). I am however not sure of your newly coined terms verilogness and vhdlness but it makes sense. At least it is a bit of a change from the boring tech posts. Apologies.
