19 years agoVCCA_PLLn
I know the Stratix II device handbook says I must connect the VCCA_PLLn even if I'm not using PLLn. But do I really have to? What will happen if I don't? I want to save all the power I can.
19 years agoAs long as you aren't using any PLLs then filtering isn't required. If you are using a subset of the PLLs then it is best practice to use filtering on the PLL VCCA pins.
