16 years agoVarible clock rate
Hello together I have a verilog-module that is working with an external 25 MHz clock. Now in my application I would like to work with a variable clock rate. Some other logic modules in the FPG...
16 years agoHi,
First you shouldn't reset the accumulator and second you shouldn't add accum to itself. see my previous post: add bits 31:0 of accum to increment and assign result to accum 32:0 The binary counter should be allowed free running without reset once it starts. The increment value can be changed on the fly.
