13 years agoUTC time stamp in FPGA
Hello! I am working on a project where I need to use the UTC time stamp and date. I am not sure how I can implement it. Is there any opensource IP (so far I didn't find any) to do that or does it com...
13 years agoI use a generic register to store a timestamp and set that generic in a pre-flow script, eg., the Tcl command looks like this:
# Timestamp integer
set timestamp
# Top-level timestamp generic
set_parameter -name TIMESTAMP $timestamp
This code can be found in the boards directory of the code for this tutorial: http://www.ovro.caltech.edu/~dwh/correlator/pdf/esc-104paper_hawkins.pdf I forget if this timestamp is in UTC format. If it is not, then you can either use Tcl to calculate it, or use another command. For example, you can also use Tcl exec to call the Cygwin date command which can produce UTC format. Cheers, Dave
