15 years agoUsing the ALTLVDS_RX DDR in = DDR out?
Hi, Can anyone tell me that by using ALTLVDS_RX core provided by Altera, and if i use deserialization factor of 6; if the input in DDR format, the output of this block will be in DDR format too...
15 years ago --- Quote Start --- The data will be 6 bits per rising edge of the outclock, so SDR. It's independent of the I/O standard, so even if you make the inputs LVDS, it will still be SDR format into the fabric. --- Quote End --- I think you are right.. so basically the ALTLVDS_RX does the job of ALTDDIO and shift register and bit allignment? Michael
