9 years agoUsing Qsys SRAM and SDRAM controllers without a Nios II
I need to communicate with the SRAM in the DE2-115 board using purely VHDL code. No Nios II. Later I may have to use the SDRAM instead if bigge memory is required. I understand that a controlle...
9 years agoFrom my experience, it is much easier to package your code in QSYS component and start communication with the SDRAM, so I agree with ted.
It is easier to understand the Avalon_MM interface than trying to work directly with the SDRAM controller. You will need to write your own custom Avalon-Master. You may find tutorials that explain that.
