9 years agoUsing Qsys SRAM and SDRAM controllers without a Nios II
I need to communicate with the SRAM in the DE2-115 board using purely VHDL code. No Nios II. Later I may have to use the SDRAM instead if bigge memory is required. I understand that a controlle...
9 years agoaha, that means I will have to understand how to read/write using the Avalon-MM bus. As far as I am aware, that should be simple.
So the bundle of wires used for the SRAM controller Avalon-MM shall be exported as a conduit?
