ZC0001
4 years agoUsing MX25L12833FMI-10G to configure Cyclone V
Hi,all
I now use MX25L12835FMI-10G to configure Cyclone V FPGA in AS mode.The program file can
be successfully downloaded to MX25L12835FMI-10G ,but when power on the board again,the configuratio...
YuanLi_S_Intel
4 years agoHi, first of all, may i know how do you determine the configuration failure? Also, can you try to program the JIC into the flash devices without ticking the "verify" option?
- ZC00014 years ago
Hi,Thanks for your reply.
There are several Leds drived by FPGA IO to indicate the status of FPGA. If FPGA is configured successfully,some of the Leds will flashes periodically. But actually, these Leds are always on after power up. The FPGA works normally if .sof format program is downloaded into.
In addition, the program can be downloaded into the flash device successfully without checking "verify" option.
Looking forward your reply.
Thank you.
