14 years agoUsing half of DDR2 SO-DIMM
I want to use 1/2 of a DDR2 so-dimm module with 32 bit wide DDR2 interface to Cyclone II. Has anyone done this? I believe this will work, provided I properly terminate the unused chips on the modul...
14 years agoI got a response from Micron's technical department. They said there is no problem leaving the pins of the unused chips floating.
