13 years agousing GPIO on DE2 board
hi, currently i'm doing a project using a sensor which has pwm output. i'm already done the coding to read the pwm output. i would like to connect the pwm output from the sensor ti de2 board as input...
13 years agoCheck the voltage compatibility first.
You will also need to connect a ground pin between your sensor and the DE2. If you are "looking" at the PWM signal using logic clocked in the FPGA, then make sure to add a synchronizer, i.e., PWM input -> synchronizer -> FPGA logic Cheers, Dave
