DGugl
7 years agoUsing differential pins with LVDS capability without buffer
Hi, this is most likely a stupidly simple question, i just wanted to know if on max10 devices once can use the differential pins without the deserializers mentioned here https://www.intel.com/conten...
Rahul_S_Intel1
7 years agoHi,
From your question, I am interpreting that the IO can be used as LVDS IO standard with out connecting to the LVDS SERDES IP.
>> Yes can be used, you have to change the IO standard to LVDS from the pin planner
