KenBee
2 years agoUsing AS and .sof
I wish to update an old Cyclone3 using usb-blaster and epcs16. Programmer selects .sof ok but tries to use JTAG. Changing mode to AS results in the .sof file being de-selected and I cannot select it ...
- 2 years ago
An .sof can only be used to program directly over JTAG. To put a programming file in a flash/config device, you need a different file format, like .pof or .jic or others.
sstrell
2 years agoAn .sof can only be used to program directly over JTAG. To put a programming file in a flash/config device, you need a different file format, like .pof or .jic or others.
