15 years agoUsing a signal as a clock and a condition (synchronous)
I am uncomfortable with the construction of the following code, specifically the use of a signal both as a clock and as a condition. The signal “irst” is used within the always loop as a clock and wi...
15 years ago --- Quote Start --- I am uncomfortable with the construction of the following code, specifically the use of a signal both as a clock and as a condition. The signal “irst” is used within the always loop as a clock and within the “if” statement as a test condition. The decisions are synchronous with the specified clocks “<=”. My understanding of the “<=” convention is the value of the signal previous to the occurrence of the corresponding clock is latched at the specified clock edge. I do not see how the condition of “irst” is ever satisfied with the “irst” positive clock. Within the simulation, the value of “irst” is captured. The behavior I see within the simulation is: irst set high within the “INITIAL” statement, then low after a short time. SCK begins clocking some time later. The register array sreg[] is not blank within the simulator window until after the fifth occurrence of SCK. At that time, all the registers appear with a value of “0”. code sample: module spi_slave ( CS_N, SCK, SDI, SDO, irst, iclk, orst ); ….. parameter NUM_REG = 8; integer nr; wire [11:0] rdat = {serial_in[10:0],SDI}; reg [11:0] sreg [1:NUM_REG-1]; always @(posedge irst or posedge SCK) begin // expect data to change on falling SCK if (irst) begin for(nr=1; nr<NUM_REG; nr=nr+1) sreg[nr] <= 0; end else if (&all_cnt[3:0]) begin sreg[opcode] <= rdat; end end --- Quote End --- Hi, did you see a posedge of the reset signal in your simulation ? Try to start with a "0" for irst. Kind regards GPK
