18 years agoUser Libraries (Quartus II 5.1)
Hello! It's the first time I write to a forum! I'd be very grateful to you if you help me! :) My problem is the following: I created a project with Quartus II 5.1. Particularly, I creat...
18 years agoHi!
Thank you very much for your answer ;) I found the name of the directory and the name of the schematic file differ because of a simple space. So I changed things and now they have same name. But, when I do 'Start Analysis&Synthesis' in the new project, there are always WARNINGS as the following one: Warning: Using design file ../TIMERprog/TIMERprog.bdf, which is not specified as a design file for the current project, but contains definitions for 1 design units and 1 entities in project Info: Found entity 1: TIMERprog I'd like to specify the directory of the user library and STOP...whitout having to insert design files after.... Where do I make mistakes? Is it possible or maybe in this version it isn't?! waiting for an answer, I wish you a nice day
