11 years agoUser Interface to control SRAM (cyclone iii starter kit board)
Dear Altera user, I'm using an altera board Cyclone iii start kit (with external Sram and Dram) I explain here the way I'am using it, but I'm looking for a better solution. The problem concern...
11 years ago --- Quote Start --- I guess you dev kit has a serial port interface. So I'd use it to trasfer data to and from sram. --- Quote End --- I was designing a SRAM Controller, but was unable to find a datasheet for the SRAM present in the CIII starter kit, can you kindly share the datasheet or link it would be helpful. PS:I was not able to find the datasheet over the internet. Thanks Regards.
