14 years agouse OVL (Open Verification Library) with Quartus II VHDL
Hi hi!! I'm trying to add some assertions to my VHDL design (ex. ovl_always). I got the library from accellera (V2.6), and I just don't know which files should I ADD (Assignments/files/) to my pro...
14 years agoSo guys/girls!! It was not so easy, but it works!
Step by Step: 1. Write a ovl_always checker in your VHDL source file, Add also at the header use work.std_ovl.all; use work.std_ovl_components.all; 2. Add to your Quartus project (Assignments/Settings/Files/) the next files from the OVL library std_ovl/std_ovl.vhd std_ovl/std_ovl_components.vhd std_ovl/vhdl93/syn_src/std_ovl_procs_syn.vhd std_ovl/std_ovl_clock_gating.vhd std_ovl/std_ovl_reset_gating.vhd std_ovl/ovl_always.vhd std_ovl/vhdl93/syn_src/ovl_always_rtl.vhd 3. You have to edit the ../std_ovl/vhdl93/syn_src/std_ovl_procs_syn.vhd and change all "default" with another constant name, for example "const_default" If you dont change it, quartus will come up with an error, because default is a reserved keyword ( i think its a verilog 95 reserved keyword!!!) Error (10500): VHDL syntax error at std_ovl_procs_syn.vhd(227) near text "default"; expecting "(", or an identifier ("default" is a reserved keyword), or unary operator 4. Edit also the ../std_ovl/std_ovl.vhd on line 162 change constant OVL_MSG_NUL : string(10 to ovl_msg_default_type'high) := (others => NUL); to constant OVL_MSG_NUL : string(10 to ovl_msg_default_type'high) := (others => '0'); if not youll get a Error (10606): VHDL Aggregate error at my_src.vhd(275): record aggregate must assign values to every element of record type ovl_ctrl_record 5. Thats it!!! 6. Now you can copy the constant OVL_CTRL_DEFAULTS (type ovl_ctrl_record) from std_ovl.vhd to your main source package and from there you can control "ALL" your checkers in your design!!! dont forget in your main package the: use work.std_ovl.all; 7. You can also have the checkers synthesised in hardware. For ex. The ovl_always checker have 4 inputs and one output. The inputs are clock, reset, enable and "the expresion to test" and the output fire[2 downto 0]. If enable is fixed '0'-low or fire is not connected, the checker will not be synthesised in hardware. But if you connect enable and fire, you can have your checkers in hardware and you can check asserts and coverage with the fire output (in hardware)!!!! tip: you can also include olv_never. Both checkers are very useful to get started with assertions.. checkers!!! see you girls/guys... hope it helps someone out there!! Gruß, m using : Quartus II 64-bit Version 10.0 build 262 08/18/2010 SJ Full Version
