15 years agoUse Max+Plus to load program from PLD?
Hello, I have a PLD that has a program loaded onto it, and the code has been lost. Is it possible to use Max+Plus to load the vhdl code from the chip so that the code can be used to program other PL...
15 years agoEven if you could read the bit file back from the flash, you'd have one hell of a job trying to reverse engineer it. Like Dave says, it doesnt store the source, only the bit file.
Basically, without the source code, you're scuppered
