15 years agoUse DIMM with two DQS pairs swapped?
I have a prototype board that uses a DDR2 SO-DIMM. Due to a design error, the DQS6 and DQS7 pairs are swapped. Would the design still work? The DDR interface is very slow on this board and all...
15 years agoI misread the original issue. If just the DQS pins are swapped then you need to rework the board. The DQS pins must be matched the to DQ group on the FPGA.
