17 years agoUSB or Ethernet
Hi, I have designed a board around a Stratix II and I am looking for a quicker and more efficient way to get data from the FPGA (registers read, writes, etc) than using I2C. I do not need to pr...
17 years ago --- Quote Start --- I was able to run the entire operating system for the NIOS out of onchip memory within the Stratix II. With ethernet, I need external memory to accomodate the TCP/IP stack. Jake --- Quote End --- Hi Jake, Can you elaborate on this please ? Which OS did you manage to shove into SII's internal memory (and which SII was it ?) ? Did you use a bootloader for that ? I've ran SW out of SII's internal memory in a project, but that didn't have an OS. Thanks
