17 years agoUSB or Ethernet
Hi, I have designed a board around a Stratix II and I am looking for a quicker and more efficient way to get data from the FPGA (registers read, writes, etc) than using I2C. I do not need to pr...
17 years agoConsider using an FTDI (USB) chip. FT245x USB to parallel converter chip (http://ftdichip.com/products/ft245r.htm) is a good choice.
It allows bi-directionnal transfer between PC and FPGA. Bandwidth is very good (near 12 MBits), and the chip is *VERY* easy to interface. On the PC side, Windows DLL provided by FTDI is also easy to use and well documented. In a couple of day, you shoud be done. This is the chip used in the Altera USB-Blaster. Hope this helps.
