13 years agoUSB DMA transfter stopped for Altera Cyclone V.
Hello experts, I am a USB developer. I am using the Altera Cyclone V. When I start a DMA bulk transfter, sometimes USB stopped to transfter the whole package. I have debugged for a long ti...
13 years agoI'm not a USB expert but I looked up these registers and this is what I found:
GRXFSIZ (RX FIFO Size Register) --> RX FIFO depth[13:0] GNPTXFSIZ (Non-periodic TX FIFO Size Register) -->TX FIFO Size 0 [29:16] : TX FIFO start address 0 [13:0] *** you should set the TX FIFO start address 0 to be RX FIFO depth *** HPTXFSIZ (Periodic TX FIFO Size Register) --> TX FIFO Size 1 [29:16] : TX FIFO start address 1 [14:0] *** you should set the TX FIFO start address 1 to RX FIFO depth + TX FIFO Size 0 *** So essentially you are setting up the size and start address of three FIFOs inside the internal SRAM in the USB core. At offset 0 in the SRAM is the RX FIFO, followed by the non-periodic tx FIFO, followed by the period TX FIFO. I recommend opening a service request and copying the link to this post into it: http://www.altera.com/mysupport Ask for additional information on the HPS USB core and we should be able to provide you with that information.
