15 years agoUSB Communication
Hello Frnds, I want to communicate the cyclone IV GX with the PC For that i have selected USB will be the best for my application(data rate speed is not so important). Pls guide me how to inter...
15 years ago --- Quote Start --- Thanks for your reply. Does i require Serial EEPROM(93C46)chip or it can be ignored. --- Quote End --- --- Quote Start --- Fully integrated 1024 bit EEPROM storing device descriptors and FIFO I/O configuration. --- Quote End --- I can't see any way to connect 93C46 to FT245. --- Quote Start --- Just all the Lines from FT245R is to be connected to Cyclone IV naa. --- Quote End --- D0-D7, RD,WR, RXF, TXE, PWREN. Maybe RESET. To Cyclone. Also you will need to programm this chip with FTDI utility. It's simplest way to communicate with PC.
