15 years agoUSB Blaster windows 7 64bit
I have recently acquired a cyclone 2 board, however I am having a lot of trouble getting the USB Blaster drivers to work for the device. I was wondering if anyone else has had the same problem and go...
13 years agosir, so with the help of signaltap 2 analyzer i can program cyclone 2 or i have to use stand alone programmer to do it.......
--- Quote Start --- Hi, while I'm not aware of a SignalTapII *Programmer*... SignalTapII is an integrated logic analyzer block you can activate in QuartusII (Tools => SignalTapII Logic Analyzer). This adds logic to your design and allows you to view configured internal signals which are recorded by the additional logic on the chip and uploaded to the PC via the programming hardware (USB-Blaster, ...). The Logic Analyzer Window contains also a "download" box likewise the programmer, maybe this was adressed as SignalTapII programmer... At least the SignalTapII is nothing that can be downloaded separately. --- Quote End ---
