15 years agoUSB Blaster windows 7 64bit
I have recently acquired a cyclone 2 board, however I am having a lot of trouble getting the USB Blaster drivers to work for the device. I was wondering if anyone else has had the same problem and go...
13 years agoWhat is signal tap 2 programmer?
and from where I can download? do you have a link from where I can download it?? What is the exact use of signal tap 2 programmer?? [=sagarcrystal;163057]Hi I had the same problem previously, with standalone programmer you also get Signal Tap II programmer. you can easily find the hardware device, and can program your device. --- Quote End ---
