14 years agoUSB Blaster VCC
Hello :) I'd like a quick confirmation about the USB Blaster. I'm implementing my design on a PCB, and I've to make a connector to programm my FPGA with the USB Blaster. So I decided to pr...
14 years ago --- Quote Start --- Dave, the schematic that you provided a link to is most interesting . . . so the 100 ohm buffer's in Dave's schematic provide the resistive damping in the equivalent RLC circuit that would exist on the PCB between the JTAG pins and the FPGA itself . . . buffered of course. I like it. This limits the energy going into the FPGA pins that are JTAG, which are basically designated as 2.5V for truly safe operation . . --- Quote End --- The resistor can be used for several purposes; 1) The traces are nominally source terminated transmission lines. The ideal resistance for a source termination is that it plus the driver output impedance match the transmission line impedance (typically 50-Ohms or 65-ohms depending on the trace and PCB geometry). 2) You can use it to slow down the rise-time of the buffer output; the R acts with the C load (the trace and the capacitance of the end pad). 3) Its a debug feature; you can start lifting resistors to remove components from the JTAG chain. I've had cases where an FPGA is dead. I can jumper over it, check everything else is working, and then get the FPGA removed. The placement of the board was reviewed with the assembly company (SigmaTron) to ensure the board could be reworked. --- Quote Start --- I have thought for a long time to make a small board that would be a JTAG adapter. It would have a CPLD on it, that would take in multiple types of JTAG cables (Altera and Terasic/Altera clones, for example) and then provide the appropriate target board JTAG signals, whether the target board be at 100 mil pitch, 50 mil pitch, etc. What you have done is very similar to this, but located on the board itself, and with digital logic rather than a CPLD. --- Quote End --- The problem with this type of board is that there is no generic hook into the Altera software. To make a general purpose board, you need to have your adapter be able to fool Quartus into thinking it is communicating with a USB Blaster. That information is not provided by Altera, however, there is enough information on the internet to build your own FT245+CPLD or Cypress FX2 USB-Blaster. Its an interesting challenge :) Cheers, Dave
