18 years agoUSB Blaster Rev. B compatibly with Cyclone III Starter Board???
I am working with the Nios II Emb. Eval. Kit Cyclone III Edition and I am trying to configure the FPGA by USB Blaster Rev. B (taken from an Cyclone II Dev. Kit). But the connection is very unstable. ...
18 years agoAdding a capacitor has a similar effect as increasing the series resistor, if ringing clock transitions are seen at the FPGA input (and probably counted as double pulses or causing timing violation in JTAG logic), the said measures may reduce the effect. If a Altera suggestion exists, I would give it priority.
I also didn't understand the reports regarding USB connection technically. The observation may be wrong.
