18 years agoUSB Blaster Rev. B compatibly with Cyclone III Starter Board???
I am working with the Nios II Emb. Eval. Kit Cyclone III Edition and I am trying to configure the FPGA by USB Blaster Rev. B (taken from an Cyclone II Dev. Kit). But the connection is very unstable. ...
18 years agoI am a bit confused as the R14 is already a 100 Ohm resistor?! Nevertheless I have absolutely no idea where the problem could come from? So lets exclude some things...
- configuration scheme should have nothing to do with it (AP or PS) - unused pins should be set to input tri-stated What about the DP-Pins? Because the QII Help tells me for me conf_done error message, that there might be a problem with the NCE pin (not at GND)???
