9 years agoUSB Blaster for DE1 board
Hi, I am new to Altera DE1 board. When I connected DE1 board, "found new hardware" window is not popping up in windows 8.1 computer. What should I do to install USB blaster...???? TIA.
9 years agoThe simplest way to install the USB blaster drivers is actually not through Device Manager.
I realised only recently that Quartus does come with an installer package for the drivers, which for some reason doesn't run during the installation process. Simply run one of the following: From Powershell:$env:QUARTUS_ROOTDIR\drivers\DPInst.exe From CMD: %QUARTUS_ROOTDIR%\drivers\DPInst.exe From windows explorer, navigate to the directory below and double click on "DPInst.exe" C:\altera\<version number>\quartus\drivers\ That will install the USB Blaster and USB Blaster II drivers such that they will be automatically be used by Windows when you plug in the hardware. You don't have to have the hardware plugged in to install them, so useful for deploying software too.
