9 years agoUSB Blaster for DE1 board
Hi, I am new to Altera DE1 board. When I connected DE1 board, "found new hardware" window is not popping up in windows 8.1 computer. What should I do to install USB blaster...???? TIA.
9 years agoHi Zeel,
Before you begin the installation, verify that the USB-Blaster II driver is located in your directory: \<Quartus Prime system directory>\drivers\usb-blaster-ii. 1. Connect the download cable to your computer’s USB port. When plugged in for the first time, a message appears stating Device driver software was not successfully installed. 2. From the Windows Device Manager, locate Other devices and right-click the top USB-BlasterII 3. On the right-click menu, click Update Driver Software. The Update Driver Software - USB BlasterII dialog appears. 4. Click Browse my computer for driver software to continue. 5. Click Browse… and browse to the location of the driver on your system: \<Quartus Prime system directory>\drivers\usb-blaster-ii. Click OK. 6. Click Next to install the driver. 7. Click Install when asked if you want to install. Best regards, KhaiQ (This message was posted on behalf of Intel Corporation)
