16 years agoUSB Blaster driver for Max+plus II
I am using MAX+PLUS II trying to program EPM7128STC100-15. I have a USB Blaster download cable. I can not install the driver. The instruction on Altera website does not apply because it's for Quar...
FvM
2 years agoHi,
I didn't yet test the tu-chemnitz USB2LPT solution. But according to reports it does proper LPT port register virtualization and thus should work. The driver software is still maintained and supports Windows 11. Problem is however that MAX+plus II and also Quartus ByteBlaster don't have 64-Bit kernel drivers. You need to run a 32-Bit OS to use MAX+plus II or Quartus with ByteBlaster. According to above posted link, this can be also a virtual machine on VirtualBox.
